meinschaft
Amazon has a Battery Tender 240CCA for 112.04
So far, no problems and they recommend the Battery Tender Jr as the means to keep it tip-top if sitting for a spell.
This looks like a great deal. 3 year warranty; 240 cca.
The Shorai I purchased is smaller than a stock battery and cost me only a few dollars more than a replacement Yuasa battery. The weight savings is huge and the extra space is nice to have as well. No battery tender needed unless you have something that drains the battery. I have had it since June 2012. I have a fuse block velcroed to the battery to make use of the extra space.
I always keep my FZ1 on a Battery Tender and the orig. battery is still strong after 3+ years. When it dies I'll put a new Yuasa battery in it and carry on. If you take care of a lead acid battery they will last a long time, but most people don't take care of them and suffer premature failure. The weight savings of a Lithium Ion battery has little real world significance for a street bike.
You do save some space with the Li Ion battery, the volume is about 1/2 so this could come in handy I suppose if you need the extra space. The weight savings is about 6.6 lbs according to the specs, a gallon of gas weighs about 6.2 lbs so, in effect, you are permanently riding with the equivalent of one gallon less in the fuel tank. This will not be perceptible on the street as I've never felt any handling difference with full tank vs. the tank when it goes on reserve (about 22 lbs of fuel less in the tank). Yes they are much lighter, but it really is nothing in the scheme of things.
If they last longer and are more durable then there might be a real world advantage, but I think they are still new enough that we don't know for sure yet how they hold up long term. Bottom line I don't think there is that much advantage.
Which Shorai did you get? I've seen references that both an 8 and a 12 are "right" for the FZ1.
Sent from my SCH-I535 using Tapatalk[/QUOTE
In Australia they recommend the LFX18A1-BS12 that's the one I have,very happy with it![]()
I have the impression that the FZ1's charging system is anemic, but that Lithium batteries require a slightly higher voltage to properly charge (than lead/agm/gel). Has anyone running a Lithium battery made any changes to their bike charging system? I've read a few forum posts elsewhere that an aftermarket regulator/rectifier is necessary to adequately charge the Lithium batteries.
They sure are heavy. I had a Corbin on both the 919 and the VFR. I swear they're 3x the weight of the stock seat. Well worth it, mind you
