What does this connection do?
jsnone1
May 17, 2012
33
Lafayette
Bike would turn over and fire, but would not start. decided to pull the carbs (which Ive never done). got to the step where you unhook the electrical connection (http://www.cartestsoftware.com/fz1/images/electricalconnector.jpg) and I see this....
What does that terminal inside this connector do? would this be why bike wouldnt run by chance?!
Going to wait to pull carbs till I see if that this is what is possibly keeping it from starting/running
A brief explanation of the answer would have been nice vs. going to another forum and having to click through a half dozen other links to additional threads. Especially after someone asked what was the answer.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Its the rectifier
I have the same problem but my bike will start ans running until i turn off the bike and battery dont have enought power to restart but i do have 2 white câble from that connection that are.cooked in trying to find a diagram how to test the rectifier
Its the rectifier
Yours sounds more like a stator issue than voltage regulator/ rectifier. Could be either but usually the stator is the cause of a no charge issue. Often times is a voltage reg/ rectifier is bad it will blow out lights etc because there is no limit to the power output of the stator. Which also puts out AC hence the need for a rectifier.
I did test the stator with the manual and also bought a new stator but i can see the same result with my tester the old and the new one. and i just open the cover and it dosent look too dark or burn but i do have the rectifier connection the whites cables wires are burn a little
You'll likely never be able to look at a stator and see if it's bad. I've replaced several and never had one look bad. However if it ohms out good it likely is. Change the regulator first obviously but stators can ohm out fine and still be bad.
