Warner24
I'm thinking of installing a PC3 on my stock 08 FZ1. Is there any advantage to this without adding any mods, exhaust, air box, etc? There is a plan to put an aftermarket slip on down the road, maybe next year.
I haven't read much on the PC3 but I would see very little advantage, especially with only adding a slip on. You can do a slip on without the PC3.
all bikes need to be tuned. stock or not. you don't just tune it because you're modding it. all bikes need to be tuned. stock or not. i said it twice because that's how important it is. no one understands this and it drives me nuts. get a pc on it, get it on a dyno and i hope you have a competent tuner and you won't believe that your bike tuned was the same one as before.
I agree with the above, but he didn't say dyno tuned. He just said stick a PC3 on it.
Is there any benefit of just throwing a PC3 on it -- I don't think so.
Throwing a PC3 and having it DYNO tuned by a reputable tuner -- Absolutely
Be good if Ivan bring`s out a flash for a stock bike,this would be the better way to go.If you're going to get a Power Commander, get the V. Just order for an 09. To answer your original question, I'd probably pass until you start adding a pipe and/or air kit. Also, I think Ivan may be coming out with a flash for a stock bike.
