Lonney
Dam Blanchy sounds like your not havin much luck with your mods bud WTF. I hope you get your sheet figured out man your bike does look nice though!
Hi Erci, I came to the same conclusion on the K&N filter. I was going to either cut some out of the groove to lower the filter on the seat, or cut some off the top of the filter to lower the metal bracket. Then I thought WTF, I paid good money for this. I called the company I bought it from, they replaced it with a BMC filter free of charge. Why should you have to mess with it. Get your money back & buy one that fits.
My brother bought a K&N filter for his Peugeot 205 GTi which didn't fit properly either. They need to lift their game.
As for the warped air box cover, stick it in the sun to heat it up & it should mould back to its original shape.
Yea, with all the other choices out there there is no need to be mucking around with the filter. K & N really need to get their quality control issue rectified. I have used their filters in the past w/o any issues, but on the FZ1 I went with a BMC and it fits great :tup:
Try a heat gun on it if the sun is not enough. Don't melt it, just get it hot enough that it is uncomfortable to touch not painful. I have returned a bent plastic bumper on a car that way before.Do you think that if the top air filter cover isn't closed all the way it could cause a vibration at those seems where it's not touching? I noticed mine is warped from using a K&n filter and even now with the filter out, the case stays warped. Anyway to fix it aside from ordering a new one?
How ironic.. I *just* dropped a K&N in, yesterday and sure enough I have exactly the same issue on my 07!
I took the filter back out and carefully inspected it to figure out the cause. Take a look at the pics below. I'm pretty sure that no amount of trimming the metal plate will help.
As you can see, the plate fits perfectly inside the top of the box.. nothing to trim here.
Here is where I think the problem lies: The height of K&N + plate (carefully seated) sits higher than stock.
K&N:
Stock:
See how the stock filter edge sits deeper in the box? I see no way of making this work.
Disappointing and annoying, since it takes 350 bolts and screws to get to the filter and now I'll have to go through it again *insert violin smiley here*
Not sure if I have said it here but this sort of issue should be bought to the attention of K & N. I have but think I have just been shrugged off with a new filter. Everyone that has or had a non fitting filter should contact K & N.
Part of an email reply I got
"On the air box we have here, there is a slight gap with both the OE and K&N air filter. We have seen where the air box is warped a little causing the fitment of the two halves to show a slight gap even with the OE filter. We have also seen that there are slight differences between 2 air boxes for the same model or application where a filter fits fine on one, but not the other. The lid on the air box has a groove with an O-ring installed, and the base of the air box has a tongue that goes into the grove of the lid. Taking a couple quick measurements there is good interference with these two features on the filter and will seal even with a slight gap on the halves of the air box."
So according to K & N it will still seal.
Agree but the same filter fits the FZ8 also so number grow.I had a feeling they wouldn't decide to re-design the filter. My air box clearly seals perfectly with stock and leaves a sizable gap with K&N. Even if it does seal properly, no sense in warping the air box.
I bet if enough people reached out to K&N, they would do something about it, but 3 or 4 (or even 10).. not worth the redesign I guess.
Yep just a fob off and my 1st thought was you've already warped the box dimwit.In other words, it fits good enough, maybe. As I read the K&N reply all I could think of was their legal dept. carefully editing it (CYA) before it was sent.
If there are the OEM production variances K&N claims, shouldn't there be fitment problems with any filter, including the OEM air filter? Is their OEM airbox warped because they had a K&N filter in it long enough to deform it?
