Happy Easter everyone! I didn't get downstairs until 10am this morning. I immediately got started cleaning the front calipers before anything else.
After they were as clean as I could get them without having to remove them, I set up a kerosene bath for the chain. I took the tupperware I cut down from work and set it atop my oil catch pan. I laid the chain submerged in it. You could immediately see rust floating away from it. Tomorrow I'll go in and rotate it to the next section, and keep doing it until I make a complete revolution. Then I'll spray it down with a healthy dose of WD-40.
I then masked off the engine with cardboard and shot the now clean headers with black VHT Paint. The same stuff I used on the mid-pipe. Should be good from now on since this bike will NEVER see another drop of rain!
I got the first fork inserted into the triples and just snug it in place.
The second fork went in the same as the first.
I locked the forks about two inches above the top triple at first in order to tighten down the caps. Once they were tight, I lowered them to spec height and tightened and torqued all the pinch bolts.
The clip-ons were adjusted and tightened and the forks were done.
I cleaned the front spacer and speedo gear assembly and got ready for the wheel.
I made sure to get the "rear" front fender on first this time. The last time I did this backwards and had to remove the wheel again to get the bolts in. Live and learn!
I greased up the front axle with some bearing grease.
Front wheel installed!
I sat and polished the fender bolts with scotch brite and installed the front fender.
Once that was done I sat and polished the front caliper bolts and installed both front calipers.
She's half a roller again!!!
So I crossed another couple of items from my list and leaves me with just a few minor things which I'll button up next Saturday. Almost ready to ride her again!!
