Break-in period
Wow. So if you read the periodic table of elements in an old text book from the 1880's does that mean you think is if wrong?
Next time I won't post anything and you can continue to live on ignorance.
It wasn't him that was poopooing MotoMan'sMotoMethodMotoBreakInSecrets, it was me.
:teeter:
I simply don't judge the person as credible. Whether his information is sound or not doesn't matter because his method of expressing his opinion/findings/information is shit. It's akin to a preacher on a street corner yelling and screaming and slandering everyone.
Again, I didn't say he wasn't right, he probably is. If I ever bought a new bike, I'd probably try that method too. :)
Thanks. It's important for me to get information confirmed from different sources.
There was a test of different break in methods by a German motorcycle magazine. They used a "hard" from the first day compared to the manual break in with several bikes and did not find any trend. The spread was about 4% in power after braking in but non of the methods gave always more power.
However they stated that you always have to put the engine to gradually to higher temperature by going faster over longer times. This means after the 1000 miles break in of the manual they drove 90 min the bike and increased the speed gradually to max speed holding it for about 20 min.
That is possible either on the Autobahn or you go to a dyno.
In general I used their method with new bikes but never dynoed any of them. However the high temperature under high stress of the motor will help settle all components. The reason why they said not to do this from the beginning is that you can have metal residuals in the engine especially in water cooled engines if the polishing was not perfect. That would be rare but better save than sorry. Another thing to take into consideration is that if you have some faulty component, chances are higher to recognize it in the initial slow break in then on max speed which might be dangerous. On a dyno this
is of course of no concern.
One more thing they stated was that it takes up to 3500 miles (not sure I remember that exactly) until the engine is really broken in.
Well that is a bit like oil, different philosophies but most of them will work well.
Sv: Break-in period
Thanks a lot, good post!
Sent from my X-Wing
Mechanical engineer here. Long engineering career - too many degrees.
I'm going to pipe in here - because of the misinformation that is flying around. Will I ruffle some feathers - yes, I am afraid so.
I looked at the Motoman thing and lost credibility in him quickly with his bogus claims concerning piston rings. He claims the high pressure air "goes over the ring and behind it". Very poor description - indicative of a very poor understanding of design and physics principles.
I didn't bother to finish the read - or "listen" if there was video. He is not knowledgeable.
The engine designers provided their break-in recommendations based on their design work and vast experience with engines. It is not hocus-pocus that they are providing.
But there are some out there that do provide hocus-pocus.
I doubt Motoman has any credentials for making the claims that he does. If he were technically educated he would not sound like he is not.
Motoman's claims seem to be all wrapped up in the piston rings. (At least that is all the farther I was able to read without rejecting his claims - not wanting to waste my time). There is an enormous amount of metal to metal contact that is going on in a new engine - not just piston rings. Valves, valve guides, cams, camshaft bearings, timing gear, wrist pins, connecting rod bearings, crankshaft main bearings, oil pump bearings and seals, cam followers, cam bearings, and on and on - not just rings.
The guy is like a clown.
All these mating devices, materials, surfaces have high spots on them, when new and first assembled, that must be smoothed off during the run-in period (break-in). And the smoothing off of high spots creates metal debris - circulating in the oil - which must be removed. The sooner the stuff is removed - the better - the less damage it can do, as it is circulated through the engine as a very fine grit.
Yes - the filter takes it out - to an extent. The filter does not get the very finest particles - that is why an early oil change is very important. And filter change is important too - because the filter will get "used up" - it's surfaces clogged with debris. Changing to a very fine filtration filter early is very important. The sooner you get debris out of the engine the better. And the first filter change could actually be followed by another after not too long a period. It would do nothing but improve the situation.
Can you ignore this stuff and do other stuff. Sure. And you will not know what the effect is for many many miles. So there is no way for a customer type person to know what the effect is on their engine - of the technique that they are using.
But the manufacturer's engineers know. They are highly educated in every aspect of these engines. Why would you want to ignore these engineers - in favor of some dummy who just makes up stuff??
Only paying attention to the people who have the real knowledge and understanding is useful. And that is the engineers who design and test these engines. Their mechanical knowledge coupled with their decades of testing experience is the only real useful knowledge.
Not some guy's made-up technique.
It was amusing - Motoman's webpage had a statement on it - something like "knowledge is power". I thought that was backwards in his case. It is obvious that he is uneducated in these matters.
As for the one poster here who claimed that he knows "dyno breakin" is the way to go - or something like that. Because he has seen it hundreds of times. What BS. It's embarrassing how little he understands. He may have seen machines on dynos - but he has no way of knowing how those same machines would have behaved or lived if they had been "broken-in" in a different manner. To sit and watch a machine run - tells you nothing about what could have been - or what will become - as that machine goes out into the world and tries to make it to 100,000 miles or so.
There is a lot of misinformation, made-up stuff, passed down made-up stuff, and emotionalism when it comes to this stuff. But that is not what counts. What counts is the physics, dynamics,metallurgy, chemistry, machining, etc ... the engineering that is involved in these machines or any machine.
This stuff is not just dreamed up - but many uneducated people do dream up stuff - and convince others that it is real. They try to pass themselves off as "experts". My suggestion is go to school and work on studying this stuff in detail - it will take some college degrees, though - if yoiu really want to understand what is going on. Don't just make it up.
Engines require careful running while their parts are being meshed for the first times. Heat and debris is created when high spots collide. The oil system circulates this debris - which in turn causes scrapings and collisions with other parts - causing damage. The filter doesn't get it all - and can't get it before it it circulates completely through the engine - to get to the filter.
This is complex stuff. I cannot do justice to the subject in a short little motorcycle forum write-up. I cannot even use the proper language to describe this stuff because most would not understand it. So I have used "sorta - talk around talk". And I criticize myself for sloppy incomplete descriptions. There is a lot more here.
But the designers cannot explain all this stuff to people - their customers. It would take a LOT of discussion - which most could not understand. So they boil it down to "recommendations". What else can they do. They have told you - what you should do. If you chose to ignore them - they can't control that. It is your machine now.
Myself - I hate seeing what a lot of people do to their machines. I hate to see engines abused. I always have.
Try to believe the designers - the engineers. They know. Don't make up stuff.
Your Yamaha engine was assembled, put in your bike, wheeled around to the dyno, givien a couple minutes to warm up and then put on the dyno for an idle test and then a full sweep high rpm power check. If everything looks right, it is sent off for crating. Yep, the manufacturers know best.
Wow!
This is such uninformed, negative thinking!
Your most gracious attack has been duly noted.
Good luck.
Sv: Break-in period
Wow!
Good luck.
Thanks for your post lindy. Now I'm definitely convinced. As I was driving home from the dealer yesterday I couldn't torture my engine as motoman says that you should so i ran it at freeway speed below 6k rpm with a couple of runs over that. I really hope those runs haven't messed anything up ..
Sent from my X-Wing
Sent from my X-Wing
Not at all. There leeway to it. It's the extremes and holding at constant which isn't the best. Ease into higher rpm stuff. But do some.
Change the oil and filter early. It's the best you can do for a long life engine.
Wow!
Good luck.
Sorry if it came off as an attack. Generally try to stay on the fence when topics of oil, tyres, chain lube and such spring up... I was attempting to be neutral and just state the facts as I saw them at the factory. It was in no way meant to bring into doubt your professionalism, credentials or time honed opinions lindy.
I didn't go on to mention that I did a motomanish break in on my own FZ1 which is now at around 103,000km and still has good compression and showed no significant power loss on the dyno when checked 3 weeks ago. Maybe 3-5 horses have escaped, it doesn't blow any smoke even though it has been tracked, toured, drag raced and regularly sees spirited riding.
And when spending 3 months in the hospital with (knee injuries, not mental :D) a Honda (former 500GP) engineer told me that the sportbike engines these days are one of the best cost/performance expressions of mechanical precision on the road today, very clean, rotated and flushed on assembly and that they still advise the soft break in to minimize amateur mistakes that may cause premature damage such as gearbox damage and to allow ALL riders a fair learning curve to avoid the superbike scare that brought on the 100hp limit we 'unofficially' have had here in Japan since the early super-bike days.
I'll just head back over to the fence now.
I have an off-topic question, about gutting the cat: Will that improve something, and make something worse ? I remember my 2T had to have some resistance in the exhaust system, is that the case with 4T, and especially the FZ1 ? I just bought a new 2011 FZ1 and I'm thinking about what improvements to make. I have a Yoshimura TRC lying on the workbench, the graves intake pipes, k&n filter, no airbox mod (yet .. I didn't think it made a big difference on the other bike, I even thought I could notice some throttle hesitation)
