Ok guys update:
Brakes:
I am having the Hel lines installed by my local shop on Thursday, for some reason I'd feel safer having them do it, although I know shops make mistakes too.
****When I have them putting the lines on do you think I should do new brake pads and/or rotors?
I get a lot of brake squeek and when I put the bike up on the stand and rotate the rear and front wheel, they don't rotate freely, they grate/friciton rub for about 1/4 to 1/2 a rotation. I know the rotors could be warped (or slightly bent from crash). The bike only has 6300 miles on it. From what I understand is that a properly setup brake system will make no noise when spinning freely on the stand.
Would I be ok to just do the lines, because I have all the parts for that now and wait a little while longer for pads and rotors?
Electrical:
My friend who is an electrical engineer is going to help me with all the soldering and make sure it's all ok. I got all the wires from the wiring harness separated out. I'm going to go to Bob's Used Bike Parts and buy 4 used turn signals. He has a rubbermaid bin of them on the floor at his place and I think they are $5 a piece, or they may even give me a couple. I'm going to butcher the turn signals for the plugs and solder them onto my LED signals.
For the euro harness I'm going to check out an electrical connector store and see if they have the matching plug for that harness.
In the end I will have the Xenon H4 headlight, 2 browlights, 2 Front LED turn signals (maybe running lights), 2 rear LED turn signals, LED tailight with Integrated signals. For all you electrical geniuses out there, do you think I will need any resistors to control the blinker speed with this setup?
Wish me luck this should be a big week, and I will be so close to being done. I just plan on replacing the airbox cover and buying the FZ1N rad guards, ohhh and powder/ceramic coating the header, rearsets, and passenger peg hangers.
