pilot8127
Double--T-Rex
Hey Speedy!! I mounted the "rear-slider(s)" in the passenger foot peg bracket on the leftside. I tired to get it in the pic. I used one hole and plugged the other. I bought a grade-8, 10MM hex-head bolt that was long enough to reach through when mounting the muffler bracket on the right.
I don't carry passengers so I removed the pegs of course. I also bought the longer TR sliders for the rear-end hoping they would better protect the "wider" back plastics in case of a tip over. :cheers:
Im on the t-rex website about to order some stuff (swingarm spools, axle sliders, and frame sliders). How many frame sliders do I need. You said you are using 2 per side on your Gen I, correct? Would I want to do this on my Gen II, and if so where would the second set mount?
