SpeedDoesntKill
Hey everyone, 2001 FZ1. Currently doing a wheel bearing replacement all around. 4 of the 5 bearings replaced with no issues till the needle bearing in the rear wheel. After 2 attempts still no good. I've removed all metal burs and even given the spot that it gets stuck on a bit of a taper with the dremel. Second attempt bearing at 29o and the axle area where the bearing goes at about 240o still no good! Ive checked part #'s everything is right?? Anyone done this recently, any help would be great!!
