klj7734
Ok, so I have the bike on the center stand and it shifts through all the gears without the clutch. Clutch pulled in will not stop the wheel from spinning. I put it in neutral, take it off the center stand, put it into 1st and the bike dies. I adjusted the clutch cable to spec and I bypassed the side stand and clutch switches and it still does it. What else might it be before I pull the clutch cover and check to see if the plug has popped out? Thanks for any help.
