Watsen flushmounts on lower fairing?
modified
will the watsen flushmounts work with the lower fairing kit that is on my FZ1, anybody know?
According to another member with a full lower kit on his Gen 2, not "out of the box". The hole is too big, (big enough for the OEM signal stock to fit through). You could (with a little enginuity) attach the Watsen signal to that "stock" from the OEM signal, (they will come apart), I've done it. Then the signal should be at just the right spot.
