Gohot229
Wizard
I'm going on a bit over a thousand miles using Mobil 1 synthetic, this is what I'v found.....
Shifting is silky smooth, it clicks into gear with the slightest urge, except for from neutral into first at a stop. this is standard on almost every bike made period. However rowing through the gears either upshifting or downshifting is far smoother than it ever was with petrolium based oils.
Clutch action is way improved, yet with no slippage when fully engaged and in gear.
The somewhat jerky takeoff or low speed throttle acceleration transition has become near perfect, without the "lurch" from zero to partial throttle. Take-off's are much easier to do smoothly.
There is virtually zero oil consumption and the oil color has remained like honey in color with verry little carbon contamination, if any. Mind you, this Mobil 1 synthetic, but I believe simmilar findings will be exibited with all the other standard Synthetic oils. There are signifficant 'possative' charictoristics being displayed when useing the synthetic to warrant its increased cost. I will never return to petroleum based oils again, theres a night and day difference in the 'before' and 'after'. Oil changes should be a do-it yourself affair fo all but the most sissy of riders, theres even several filters that have the hex-headed nut shape molded into the oilfilter to facilitate using a wrench to remove and reinstall it, for others a simple oil filter wrench from nearly every auto parts is available. Doing it yourself will offset the increased cost of the synthetic oil and appropriate filters, Compared to a shop price. It is so easy, every one should do it, and I don't think the warranty is affected.
