Tach error code '7'?
Thanks! Do you know if anything related to the EXUP valve could also cause an electrical problem which would reset my electronic gauge (and trip odometers)?
That can also mean your Throttle Position Sensor has an issue or is becoming unplugged. The TPS sensor uses the tach to tell you where to set the TPS. Dont quote me but i believe when the tach says 3,000 the angle is two small, when it points to 7,000 theres to much angle, and when it points to 5,000 your about perfect. The TPS is mounted with security torx screws, good luck.
