supersonic
I recently bought my first roadbike after riding motocross for 30 years. It's an FZ1N '06. I weigh 76kg (160lbs), any tips out ther for suspension set up?
Yes, I agree that the front feels unsure, my bike has only done 3500km's, so that combined with my lack of road experience will make it a little hard to set up right now. From my experience most MX bikes come from the factory needing re valving for my weight, to get a nice plush feel. Thanks for the info.The 06 had a 600lb spring the 07/08 went to a 700lb, at 76kg it should be ok for you i can remember of hand the setup dimensions and sag, i have a stock 06 FZ1 shock 10,000km if you want it i am in NZ, the rear i could live with but i found the front a nightmare the lack of adjustment and a wooden feelling made the ride harsh. After a few racetech bits and pieces it handles like a dream and you may consider a steering dampner it makes a big difference. Setting the suspension comes down to feel, after setting sag & co set everything else neutral find a nice stretch of road and play but make small adjustments at a time, what works for you may not work good to someone else it is all trial and error.
Hi guys.
If my bike has the standard yamaha suspention. What values do I use on the worksheet oldschool gave us?
07 Fz1s:+1:
Hi guys.
07 Fz1s:+1:
