fazernoob66
Gen1. I put my stock linkage and shock back on last night and torqued bolts to spec. It has quite a bit of free play, mostly at the frame tabs holding the linkage. This is with no load, i did not check for play before i removed it. It did not have washers when I removed, so none went back on. Is this normal?
