Richie's New Ride Is Home!!!!
Thanks Tony, you had me nervous when you said "more money", but to me anything 100 dollars or less for a motorcycle is a bargain in my eyes. 69 dollars for the progressives is a great price. I don't think he will ever need more than that. I just need to stop the fork dive from the supersoft springs up front. It gives a cushy ride and soaks up the bumps really well but for higher speed cornering, they suck, and could probably get him in trouble should he ever go in too hot. Thanks, I think I'm gonna look at the progressives with maybe a heavier weight oil. Nice find!
Yea, those should do the trick. On the Race Tech site they recommend 15W oil. You just need to find out what comes in the forks from factory and go up a grade. Here's a good article on it:
http://faq.ninja250.org/wiki/How_do_I_replace_the_fork_oil?
Replacement Shock Arrived
The rear SV650 Shock arrived yesterday at work. It looks like a nice unit. It came from an 07' SV650 and has a 430lb. spring and 7 preload adjustments. I'm hoping to at least remove the stock shock tomorrow after work and bring it upstairs to transfer the eyelet bushing from the stock shock over to the replacement. I have to say it was a bitch of a time to remove the bushing from the SV650 shock. I'm hoping the other will go easily since I can't damage it. Does anyone know an easy way to remove it? Any help would be appreciated.
The Replacement Shock.....
The difference in handling is supposed to be "day and night". I can't wait to finish the job. Then I will have to tackle the front forks.
Shock Swap In The Books!
We got home by 2:30pm and headed for the garage. I pulled the old shock from the Ninja and got to work removing the eyelet bushing which to my surprise, came out in less than a minute. The real job was to get it to fit the new shock. Instructions say to open the eyelet on the SV650 shock another 20 thousandths. Easier said than done!:confused: I started with a curved file inside the eyelet for what seemed an eternity. Set the bushing in place, nothing doing. Without a lathe or a bit that big, this was going to be a chore. I immediately went to plan "B". I sent Richie upstairs for the Dremel kit. I cut a tiny section the long way on the bushing which in theory would close it just enough to make it's diameter a perfect fit. Being that it is sandwiched in the eyelet and between the upper mount flanges, there would be nowhere for it to go. I had to be almost sure since there was no turning back once I broke that metal wheel out. Once the section was cut into the bushing, I used a 1" hose clamp to compress it closed and pressed it into the eyelet. It worked like a dream. The last 1/4" (width of the hose clamp), was pressed in the same way I removed it initially, back to back sockets with a 3/8 threaded grade 8 bolt through them. I cinched down on the nut and in went the bushing. Next I drilled out the bottom eyelets to 1/2" in order to fit the stock bolt. I grinded the lower ears a bit since they are a tiny bit narrower than stock and filed everything smooth. I lifted the new shock into place and Richie sent it home while I lifted the rear of the bike to it's new ride height. I used the rubber mallet to line up the holes. Richie inserted the bolts and we snug everything down. Once finished the difference was apparent. You can now use one finger the get the bike on the centerstand, and I think I'll be needing a longer kickstand. The bike doesn't tip over but at over 1-1/2" higher, it's real close to it's limit. I may pick up a sacraficial kickstand to cut and have welded into place to add an inch or so to the stock stand. Richie sat on the bike and is now on the balls of his feet. Also, the rear height is looking good now and there is no longer any sag in the rear. I have it set on 4 clicks preload, but it won't be until he rides it that I'll do some adjusting. Here are some shots that Richie took today.............
The two shocks side by side..........
Getting ready to remove the stock shock......
Shock removed. Didn't even have to remove the wheel......
Trying to enlarge the eyelet on the SV650 unit............
Here goes Plan "B"......................
Now to compress the bushing.............
Pressing in the bushing..................
Taking some material from the lower flanges.............
New Shock Installed !!!!!!.......................
If this mod is anything like they say it is on the 250 Ninja Forum, Richie will be having a better time on the mountain next time. Next and LAST mod, the front forks. I'm gonna use the site that Tony "the Bloodhound" sent me and go with the 70gm set of non-progressive springs with 15W oil. It's supposed to eliminate the dive and the front end more compliant for riders at about 160-170lbs. That will have to wait for another day. Thanks for looking!
Job well done Billy! I had to wonder about the cutting of the bushing but after seeing it, totally understand now. :D Are you comfortable with him not flat-footing the bike now? Or, will you cut down the spring?
Looks like you had some fun! I got stuck working on client computers all day. Ugh....
It rained here all day......just cleaned up the bike and cleaned and lubed the chain.
Yeah, today has been rain, sun, rain, sun, rain... no idea when it will stop! No riding at all this weekend.
Billy, did you see my questions above? ;)
i'll dig up the info....but there is someone on the left coast who can take a kick stand and essentially make it an adjustable -- I looked to have it done here, but they wanted a fortune and would not stand behind their work if they were to mess it up.....
guess yous guys on the the Left coast have more ingenuity to get things done by any means necessary!
coming along nicely!
I'm sorry Eric, yes I did my friend. I just haven't been able to get on the PC for any stretch of time. Richie has been taking my PC time browsing the Ninja 250R Forum.:rant: It's not that bad. He is still entirely on the balls of his feet, and almost flat footed at a stop. Also, he doesn't ride with his sneakers which is what he had on that day when we worked on the bike. With his boots, he should be back to normal. He, unlike me, has a long inseam. I suspect he'll be just fine. For now, I won't be cutting the spring down. Thanks for the concern though. We just got back a bit ago from the Englishtown Spring Swap Meet and Car Show. I'll post some pics later.
Thanks Adam. I'm gonna look on Ebay to see if anyone has a kickstand they are selling to cross-section and lengthen his. I only need about an inch of material. Maybe even a section of round bar will work. I need to check the diameter of the stand first.
If an inch is all you need, you could just take a hockey puck along to put under the stock side stand. It would be just about perfect height wise and would cost about $1.50. Soft pavement would never be a worry again.
Ya See! Thats exactly why I'm here! Thanks OldSchool! Talk about "the obvious". Your absolutely right. A hockey puck it is!!!
At least that way you don't have to worry about a weld breaking and it is ready to go instantly. Cheap is good. I did a nice little under $10 mod myself this weekend to. Will post pictures when my bike is back together.
