removing frozen brake caliper bolt
hillm250
Jul 20, 2012
90
Auburn WA
I went to remove my front wheel last night to get a new tire today, I figured this is a 15 minute job. The axle came out no problem, however all the brake caliper bolts refused. After 3 hours, lots of bolt blaster and some redneck engineering I got 3 of the 4 bolts out, (all the bolts are trashed now) 1 bolt still refuses to move. I was able to remove the caliper on one side and get the wheel off, so I should be able to reinstall with the new tire the same way.
However, at some point the frozen bolt (which is rounded off) will need to come off. I don't want to weld to it since it is close to the forks/brake caliper. Anybody have any suggestions? I want to KILL whoever changed the tire last, no anti seize was used and the bolts were torqued way past spec:mad:
heat, a good heat gun, or even proper use of a rosebud tip on a gas torch.
or if not then get a drill and drill out the bold. go a step at a time sometimes the less meat in the bold can cause it to loosen up, then at some point a "easy-out".
just drill straight and true...if not new parts needed. :banghead:
Thanks for all the suggestions. I was able to successfully remove/re-install the wheel with only 1 brake caliper removed. However if the caliper with the frozen bolt has to come off I'll try the kroil. I Also found some cool sockets at sears for removing rounded off bolts.
