RavenFZ1
I ordered Proton flushmount turn signals and from what I have read, if I install these with stock rear signals I will need an aftermarket "flasher" to make them blink at the proper rate. I read that the Tridon 552 [ame=http://www.amazon.com/gp/product/B000JZ351M/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000JZ8N8W&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1VRMGSMZ6J2E2JWXGTZT]Amazon.com: Tridon 552C Thermal Flasher: Automotive[/ame] is supposed to be a direct "plug and play" item to resolve this issue, but when I pulled the plug from the stock flasher it looks nothing like this connection.
Through further research I found that this item ELFR-1 Flasher Relay Honda Ruckus - BOWLS is supposed to be a truly plug and play solution and in looking at the connection it does appear to match the factory connection.
So.... why do people say the Tridon 552 flasher is a direct fit item when it isn't... or am I missing something? Thanks.
