yolmen
I got my fz1 01 2 weeks ago. First few days run great. After few days I noticed it was harder to fire up, then to start from light, eventually bike was not drivable. I checked the forum and everything was pointing at pilot jets. I figured I want Ivan's jet anyways so pulled the carbs, sure enough 2 pilot jets were clogged. Cleaned them and the passages. Installed Ivan kit no problems.
Installed the carbs back I had issue with TPS it was moving between 6-9 by it self. Then the battery died (great). Got new battery and was able to set it at 5k. Fired it up and had to hold little throttle just have it running. Idle screw doesn't do anything to the engine.
What's up? I wanted to sync the carbs but it will die in around 1k rpm
At one point with the choke it fired trough the exhaust witch was pretty cool. I also unscrew the mixture screw 4.5 turn out. Any suggestions? I want to ride
