Possible fuse issue.
Hello guys, just wondering if anyone has had this issue, everything is working well on my bike but a while ago the license plate light went out, I ordered a new on and it's in the mail so I don't know if it's the light or something else. Recently though, my high beam and my horn went at the same time. Is there a fuse that handles those?
Thanks in advance.
Your fuse panel is under the seat. It seems to be a fairly common issue to have a blown fuse out of nowhere, not sure why, definitely start there.
Check that your battery connections are tight. A connection that is even slightly loose can blow a fuse.
Then look for wires that may have rubbed though the insulation and are causing a short. That will pop fuses as well.
If the fuses are good then you need to check the large connector on the left side of the front fairing. The wires may have corroded which will break the circuit and cause the headlights to stay off.
