Ziemis
Hi guys. Which oil to choose? In my previous bike I put 10W40 synthetic oil. The same here or is there anything better?
Yamalube Synthetic. Designed by Yamaha for Yamaha.
Oh boy. Yamalube... made by Citgo now. Used to be made by Torco.... Made by the lowest bidder to Yamaha.
Not that there's anythign wrong with Yamalube... I know you work for Yamaha Jeff... but you know as well as anyone else... Yamaha doesn't make oil.... It's like Harley Davidson batteries... which are Yuasa batteries in a plastic HD cover. (seriously. not a different plastic body... just a cover over the Yuasa battery. You can cut it off with a knife. I've done it.)
Yamalube is made by Citgo. Yamaha doesn't make oil. And oil is just a lubricant, manufacturers don't design engines around oil they simply use oil as a lubricant in the engines they build.
That being said, I rock amsoil or if i forget to plan ahead I use Mobil 1. I used to use Rotella back in my MX days until I tore my motor down and saw how much dirty residue it left behind. Switched to amsoil and the next tear down looked shiney clean.
