mikeswe
Mounted the shock today, there where no problems, even without an assistant. I actually ordered the YA628 unit (no ABS) but I got the YA906 (ABS) instead. The only difference I can see is that the YA906 has a shorter hose to the compression reservoir to be mounted on the left side, the YA628 has it under the seat, where there is room if you dont have the ABS control unit. I don't mind having it on the left side, it looks good.
I loosened the bracket holding the rectifier/charger unit and routed the preload hose over it. It makes the hose take a nice rounded path without any kinks (see pics).
Now I have to go for a testride, with brand new tires also (Dunlop Q2). One thing I should have done is to measure the free sag before and after, but I forgot. I think it is equal to the stock unit. Shock length is 320.5mm, spring rate 120N/mm.
