DirtyD
Ok so I got my slip-on, gutted cat, Airbox mod, removed flies, ais blockoff and now a PC III, I see alot of guys disconnecting the O2 sensor do I have to with the PCIII and How do I do it... thanks a ton
ok so I installed lars map onto the PCIII installed the PCIII on the bike disconnected the main harness pluged in the PCIII and then grounded then unpluged the O2 no check engine light but it idles around 1200 rpm and bouces to about 900rpm then back up is that just the map or did i do something wrong
No I didn't...lol guess I should...thanks again! I like thisforum so much better than the other, you guys help without all the sarcasm belittling
