Speed4341
I NEED HELP ASAP AS IT IS DARK AND IM STUCK RIGHT NOW. Thank You
so I just walked outside to leave a friends house and went to start my bike and i have no headlights or instrument cluster backlighting. The turn signals, brake light, and other parts of the instrument cluster (lcd's, tachometer, neutral light...) all work. Bike starts with no problems.
Bike is stock except for motodynamics tail light which I installed 2 weeks ago(had no problems after this install) and flush mount turn front signals and led flasher relay which I installed today. During my install I simply disconnected the stock turn signals and tapped into the stock power and ground wires using these.
this is the tail light
2006 2007 2008 2009 2010 2011 2012 Yamaha FZ1 Sequential LED Tail Light Motodynamic.com
these are the flush mounts I installed
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
this is the flasher relay
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
