tonybcrazy
I recently became the proud owner of a clean 2005 FZ1 with 22k on the odometer. I have some questions about it though having now enjoyed the bike for a week or so. First during a cold start is it normal for the bike to Rev to 4k then come back the idle on its own when it first fires? I usually don't touch the throttle to get the bike to start when cold just use the choke. Next should my idle be more stable than it is. At first start it will usually idle at 1k after I am able to shut the choke off. After thuroughly warming up idle will come up to 1400 or so. Normal? Lastly I have been doing some tune up stuff. It has had sea foam in the tank for the first two fill ups. I decided to check the tps resistances and setting per the manual. The overall resistance was ok but during the sweep I never saw a reading down to .4k ohms as specified. I tried to set the tps sensor in the tach set mode but don't have the travel in the slots to rotate the sensor enough to get the 5k rpm reading. It is sitting right at the edge. Is it time for a new tps? I am hesitant due to them cost as much as they do. $153 is the best price I can find for one. Any help anyone could offer would be appreciated. Also if there is any other tune up type maintenance you suggest doing I am all ears. I am aware I have a valve check coming up soon.
