FZ1riderNY
That's true. While they don't look too much out of synch, cylinders 3 and 4 could be balanced a little better. 26 is just a number which is ideal if you can acquire it but not necessary. As long as all 4 are equal to each other or close to it your fine. I would try to balance 3 and 4 again and then do the center which will balance 1-2 with 3-4. Also I remember that on the GenI you always wanted to raise the idle a bit while balancing just to smooth things out to see where they are with each other. No more than 2500 to 3000rpms. It may not do anything but I looked closely at the photo and unless it was just the point at which you hit the shutter, the last two cylinders are not equal. They aren't bad, but not equal. I believe there is room for improvement.
