Rex D.
:shoot:I decided to change the little beep-beep horn to a pair of man-sized horns (not trying to offend the other sex!). I ordered these PIAA Sports Horns part #85110. They claim 115 DB. My concern was how to securely mount these as they are attached in the same general area as the original horn and need to move with the forks. They needed to have good clearance between the horns and the non-moving front fairing. I thought there would be a problem with having to fab. a bracket to mount them. That, as it turned out was not a problem as the original steel brackets work great, all that's required is to bend a roughly 1/4" joggle in the steel mounting brackets. This is needed to clear the front brake line, and the other one is bent to match. The horns are mounted contacting each other and a glob of RTV between them to make the whole assembly solid. I have about 3/4" of clearance between the horns and the front fairing during normal riding and about 1/2" at the extreme range of turning the forks (when parked). I used aircraft tefzel wire ( I build airplanes) for the harness and covered wire with heat shrink tube from the horns to just under the tank to blend in with the other, stock wiring. The wires follow another stock wire bundle from the forks to the tank. I used an "off the shelf" generic relay and a 15 amp fuse, these are located under the seat. The stock horn wiring won't support the amps of the new horns which is why you need a relay. I put the fuse under the seat in case there's a run-away horn and needs to be silenced.
I now have a real horn that means business!
I hope these photos turn out okay, this is my first attempt. I have text on the photos but it may just be the wrong method of posting. Any suggestions?
