missed rubber damper 06 fz1
lukach
Hello everyone,
new there...Recently i swaped my engine to new one.Valve dumped into piston :oops:...Doesnt matter, i solved problem with "new" engine which works pretty well...
After finised swap I found one rubber damper wich is now missing in my frame.From the manual sheet i cant recognize where is installed.Does anybody know?
Seems like no.21 is on the left side of the frame and no.20 is on the right.
Thank you for help.
On the opposite side there is a tab (#20), as this is 21 it is not unlikely that its similar i.e., rubber over tab but on the opposite side. See if you can locate what they are for.
