supersonic
Just bought an Ohlins on Ebay for my Gen II FZ1. Hopefully the std spring will be OK, I weigh 75kgs. Has anyone had to change their spring?
Ok thanks. I've always been in the right range with my dirtbikes.Typically when you buy a new shock the reseller will include the correct spring for you. I think you should be ok with the standard spring. I think they are meant for somebody in the 150-170 lbs range which you're in.
I'd love to go, but i'ts snowing in the mountains where I ride in the summer!I keep forgetting that this is the winter for our mates down under! Get out your rubber suit and run it through the paces!
