yolmen
I was checking my EXUP cables and they are not only totally loose but the valve seams to be in opposite direction that it should be. I figured I will open it up,clean it and apply grease. I went to advance auto parts and auto zone and this grease the only thing i found I think could work Specialty Lubricants - Anti-Seize : Permatex® Anti-Seize Lubricant
Will this do do put grease on the valve (and bolts by the way) ?
Thank you!
Thank you!
