rmadrid20
Bought this integrated tail light with blinkers and has a yellow and a blue wired and a red/white/black wiring can u help me to connect tis to my bike fz109
regards
Johnny
regards
Johnny
Well from seeing the picture this is my best guess. Adapter plugs in to existing taillight socket for running light and brake light. Blue and yellow wires are for left and right turn signals?
Yeah, that sounds about right. I put one in on my 08. and had to do a little trial and error because the wires had to be cut to remove the factory bumber that it comes with lol. If you notice that nothing is working after touching some wires together to match the Right and left, don't panic....all you did was blow a fuse....and the bike comes with a few spares. So you should be ok. The turn signals will more than likely blink a little faster than your used to, but it's not as bad as when a car's blinker goes out and blinks like it's on crack. Just a little faster than normal, but all other wires, including the license plate light should be capped off or taped off, so they don't ground out. Otherwise you should be good to go!Bought this integrated tail light with blinkers and has a yellow and a blue wired and a red/white/black wiring can u help me to connect tis to my bike fz109
regards
Johnny
