If you want to set your lights beam(FZ1N)
jskf16
www.fazerclub.gr
Direction (for vertically adjust)
a headlight beam is raised
b headlight beam is lowered
Direction (for horizontally adjust)
a headlight beam moves to the left
b headlight beam moves to the right
Are those the srews that hold the fariing on? I had those out trying to deal with the faring buzz. Now this post says my headlight alignment may be out-of-whack.
The adjustment screws just adjust the headlight position... they don't hold anything else on. I know on the Gen 1, on the back of the headlight, there are several bigger screws that hold the headlight to the fairing stay bracket and then there are several smaller black headed screws with a phillips in the middle, and a hex head on the outside of the screw head. Those are the adjusters. If you had been fiddling with these screws, you would have noticed that you can turn them all day long, and they don't come out.
