Doing things like adding some sort of water wetter or toggle switch for the fans might make you feel good but they really aren't needed.
I agree. But since I enjoy doing small “projects” – especially when they are free – I figured I’d share how I wired my AUX fan switch. I don’t think I would have done this if I lived up North, but it’s hot down here in central TX…
I decided to put the switch on the right/throttle side of the bike for 2 reasons.
1.) I believe the only time I’ll “flip the switch” is at a red-light, and much of that time I have the bike in-gear (for safety/escape) so my left hand is tied-up on the clutch.
2.) If I leave a red-light with the fans/switch on, I think it will reduce any temptation to turn-off the switch while riding (again for safety) so I’ll just wait till the next stop to turn it off.
Anyway – I’ve always liked the idea of being able to “un-do” a mod, and in this case I was able to tap into (probe) the back of the fan relay without cutting or stripping the factory ground/relay wire. (I have a few auto wire-harnesses, and I found a connector with thin-blade terminals that snuggly pushed/probed into the back of the relay connector. I simply secured it with a zip-tie.) The only mod I can’t “undo” is the ½” hole I drilled in the small, soft-plastic shield/guard under the right side of the fairing – but that should be pretty-much invisible unless you looked-up at it from engine level.
I had a cheap, plastic switch I pulled out of a car - I bent the terminals forward a little to help the wires lay low.
Wire path:
With loom:
Buttoned-up:
Ground to negative battery terminal:
The extra wire in this pic is just there to show the type terminal that’s probing the relay connector. I didn't even move/remove the relay off it's mount - just "plugged-in" the terminal and secured it with a zip-tie:
