v-petn
Hi all,
I've noticed that since I removed the faulty FCE, I now have a roll on hesitation below 4000 rpm, it goes away as it revs higher. It also hesitates if I cruise at 4500rpm... I checked the cables and soldered them back together so they are secure. Not sure if it could be running lean too. Mods are modded airbox, BMC air filter, gutted cat, slip on, blocked AIS and 15 tooth front sprocket . Could it be running lean or could it be something else? I was planning on buying the 2011 ecu to fix the throttle snatch on the 06 but if I can't resolve this issue then I won't take the plunge yet
