twillet
Has anyone found an aftermarket radiator? Or tried to fit an R1 rad. to the Gen II FZ1?
Whats the purpose for exchanging rad that to this?
Unless FZ1 rad dosen't do the job...
04-06 R1 radiator works. Can't transfer fans though so make sure to get the rad with fans.
Few things on install, if you go this route.
1. Fans run opposite wiring to the FZ so just swap them around or they stay on
2. Hoses fit but need a turn, pull and push here and there. I've been running my hoses for 50,000+km and no probs.
3. the lower locating bolt will need some creative extension plate. Nothing complicated. Can actually turn the stock part around and tweek it to work with washers if necessary.
