jwhelan65
Well as promised there is now a Gen I radiator guard available. I ended up using the existing frame to make for an easy installation. The only modification you may want to consider is cutting away the existing stock wire guard cover to make way for the new one. This is optional you can mount it over your existing guard with no trouble. The rubber edging snugs it up tight between the radiator columns for secure fit. Installs in minutes. Price is $43.00 shipped in Black Gold or Silver.
Again cutting the old one out is not necessary, you may want to try and run it that way first to see what kind of effect it has on cooling. Also if yours is beginning to rust it may be a good time to remove it anyway.
You can PM me if you are interested or email me [email protected]
Cheers!
Joe
Cheers!
Joe
