Pghz
Looking to buy new 2013 fz1 for 8,400 otd. Or 2014 fz-9 for 8,100 otd. What do you guys think? Btw experienced rider.
2014 fz-9 would be my choice.
Would use it for commuting and sort rides with my wife. Which I guess the fz1 would be a better ride for her.Why don't you tell us a bit about how the bike will be used?
Marthy (forum member) owns FZ09 and loves it so far, but I don't think he owned Gen II FZ1.
They're both great bikes, but my decision would be based on what I wanted the bike to do.
Benefits of FZ1: wind protection, higher speed stability, hard luggage compatibility, loads of aftermarket parts.
Benefits of FZ09 (strictly on paper.. I've yet to ride one): MUCH lighter, potentially more flickable and all around fun. It may actually feel like it has more pull at lower RPM since it's so much lighter and has plenty of low end torque.
I can't tell much about the FZ1 (unfortunately) but the 09 is a sweet ride. It all come down on what you need and what you will be using the bike for. Just to bang around town, short commute and ripping twisties under 100 MPH on one wheel (first 3 gears), the FZ-09 is for you.
If you need to go to over 100 MPH and go for a IBA saddle sore few times a year... the FZ1 will be a better choice in my opinion. But it's hard for me to compare.
All I got to say is the 09 is quite a badass machine under 100 MPH, just a blast to ride with plenty of torque about everywhere in the power band.
One last thing... 45-47 MPG @ 70 MPH cruising. Range: 140-150 miles if you milk it.
Front end spring rate is very soft. 6 turn preload = 35mm sag). Im 175 lbs and almost bottom out the fork on hard braking. Rear spring is about right for me. 3/7 on thr adjuster give me 28-30mm sag but damping sucks! All the way in on rebound and it could use some more... only adjustment.
My mod... will order a stiffer front spring with 10W oil at the front. Rear... working on it. (2008 ZX-10 triple clicker look like it might fit?) If not Penskee as something all figure out.
Thats about it I think... sound fantastic too!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Hey Marthy, I would think twice about using thicker oil in the front forks. You want to stiffen them up, not slow them down.
I would stick with stock oil weight and heavier springs.
Sent from my Nexus 5
yes, there is few members riding new fz-9 and they very happy.The fz1 got to be the faster better bike right? Anybody ride fZ9 yet?
Have you considered purchasing a used FZ1? Seeing as they are basically unchanged since 2006, a used FZ1 can be had for very little.
Tough you might like this review.
Yamaha MT 09 - Review - Test - YouTube
