Barnsleyer
Hi, has anyone found some comfortable bars for the FZ1 1000 please
I actually would like to raise my handle bars a bit because when I ride I put to much weight on my hands thus they go numb fairly quick within an hour of rideing(I also have a problem with carpel tunnel). Anyway anybody know how high of a riser I can go without haveing to change or lengthen cables and all? Is 1\" to high? Thanks
just use SV650 risers to lower bars by one inch no mods to cables. Makes a nice difference if you like a more agressive position:sport12:
If you're only looking to raise the bar 1\" I think the stock cables and brake hoses will be ok. I saw some risers that not only raised the bar, but also brought it back, but the person had to move the master cylinder slightly because the brake hoses were tight. Unfortunately I don't remember the brand of risers.
where does one get these sv650's?
those Suburban bars are a little pricy??? Are they worth it? How do they feel? How much forward do they bring you? thanks!Yeah, I went for the more agressive position on the Gen I. Lower GYTR risers with Suburban Machinery (SM2) bars.
Another alternative that can give you the largest set of riding positions, within ONE set of bars is the Converti-bars
If you happen to be on a Gen II, you might have to do some more digging b/c I don't know what is out there for them....
BroHay
