Fz1 front foot pegs.
Delta
Ok so I've bought some nice cnc blue anodised foot pegs to bling the bike a bit. The rear pegs wasn't any trouble as you pull the cotter pin from the shaft that goes through the peg and swap the new pegs, easy!
Right the front, there's no cotter pin that goes through the shaft. It looks fixed..! So do you drill out the shaft and replace it with a new one that has a cotter pin or.....?
Have any of you had this little problem and if you did how did you get round it?
I'm thinking the only way is to drill the bottom the part that looks like a fixed washer or rivet etc.
Thanks guys.
Delta
It looks like you just drill the rivet out then. I found a post via Google different bike but same type hinge pivot pins.
Aw shucks thanks guys. It is a 2006 model registered in 2007. 56 plate
What do you mean about to he black forks? That's how I got it :)
I understood ( please correct me somebody ) that all 2006 models had gold forks and the black ones introduced in 2007,, guess that would make sense if yours was a late 2006
All the fun stuff is across the pond :(
I've had to import stuff too from yanky land like the Graves verlosity stacks and the modded copperdawgs flies.
Some stuff from China too and Italy lol
It's all good and if you need/want it you import it.
Cheers
Delta
