fisherman322
Wizard
You should have no trouble levering the pads out[pushing in pistons] with a screw driver,you have to do this when changing padsok so i just pulled the caliper off the rt side with everything connected i was unable to push the pistons back in. then i cracked the bleed zerk and was still unable to push them back in. then i pulled it the caliper completly off put it on my bench. unable to push it back in. then i took the pads off and was able to push each piston back in indivudually.
does this mean i need to rebuild the caliper?
