FZ1inTX
Adminstrator
Inspired by SoCalFZRider over at FZ1OA, I decided to chop up the rear fender much like he did. I'm still working on it but I didn't want to do part two last night as it was getting late and I wanted the bike back together in case I could ride today. (Not! Damned rain!)
I started by removing the rear fender then separating the plastic from the metal bracket. I mounted just the metal back on the bike and eyed where I wanted to cut. Since I do not have a welder, I knew I had to cut and overlap the metal so I could drill and bolt it. I chose my spot and marked it, removed the bracket then cut it into the three pieces. Drilled two holes per side and bolted them overlapped. This knocked almost 4" off the length. After I bolted it. I put the metal and plastic back together as best I could and marked the new "TOP" for the plastic. I took the hacksaw to it and cut on the line. I had to get creative and cut in and around the top to fit the bracket with the welded on cap nuts. Here are the before and after shots along with a underside shot so you can see the overlap and bolts.
View attachment 440 View attachment 441
View attachment 442 View attachment 443
