oldschoolsdime92
Anyone done this? I tried it today, and it worked like a charm.
Fix for Hard Starting....Adjust Throttle Position Sensor
My new stock FZ1 has a strange start up procedure. Whether the engine is hot or cold, I do not need any choke, but I do need to crack the throttle. This is annoying and is bad for the starter and engine. I don't want to wear out the starter and I don't want to over rev the engine at start up.
I noticed that the throttle position sensor (attached to the #4 carb) allows for adjustment. The "holes" for the mounting screws are actually oval, allowing for adjustment by turning the sensor a few degrees. Mine was set 3/4 of the way clock wise. The two sensor mounting screws are tamper-proof special fasteners. I had to remove them with pliers and replace them with 4mm x 10mm Allen head metric machine screws (plus #8 flat washers and #8 lock washers). Do not loosen the silver colored Phillips head screws (they do not have to be removed).
The sensor was set at 3/4 full clock wise from the factory, so I reset it to full counter clock wise and tightened the screws. This only amounts to about 7 degrees of rotation.
Now the bike starts up with no choke and no throttle. It starts up faster so I don't have to hold the starter button nearly as long. The bike runs fine with no bad side effects. It idles smooth and makes good power (I am not claiming that the bike will run better, only that it now starts better). I just made the adjustment today, I will get back to you after a few dozen more starts.
I think this alters the ignition timing and/or cracks open the EXUP valve, but I am not sure. All I know is that it now starts like a normal bike
