FZ1George
Fitting an R1 Rear Shock to Gen 2 FZ1
I thought I'd start this thread it may have been done before but here we go.
I thought the rear suspension on my FZ1 was a bit lacking if performance and adjustment so I got to thinking will a R1 Rear shock fit. I managed to get a 07 Rear R1 shock off ebay for £20 GBP which has only covered 500 miles (so the seller said!!!!
I removed the EXUP servo to get access, once remove I unbolted the original and compared the two shocks side by side (see picture). As you can probably see the original shock is 15mm longer.
I trail fitted it anyway which as you can imagine lowered the rear quite a lot. This picture shows it fitted. I had to remove the rectifier pack and the plate it sits on because the R1 shock top reservoir gets in the way.
To compensate for the shorter shock I purchase 1 x RH threaded rose joint + 1 x LH threaded rose joint and a link bar with right and left hand thread at opposite ends this acts a rear ride height adjuster, as you can see I bought the wrong length a new one arrives tomorrow. I trial fitted it anyway and achieved the correct original ride height but with only a few threads left at each end. The rose joints are 10mm ultra high perfromance and the link bar is chrome moly steel so should be more than up to the job.
I'll post more pictures and info tomorrow when I get the new longer link bar.
Hopefully this thread may help other FZ1 rider.
