Stuuk1
Hi again,
I seem to just be getting problem after problem after problem with this bike at the moment for no apparent reason!
The story so far, I have battled with fault code 20 and Ivan's FCE for what seems like forever and finally decided to rip the bloody thing out. So took the bike to bits and finally got to take it out until I noticed a loose connection!
I then noticed that all other connections were soldered and this one wasn't, so re-crimped the connection and Voila, fault code 20 gone.
So, bike back together, all hoses back on, connections back together (Also re-routed cabling and PC3 + Ignition Module from mid-point to under the rear seat).
Started the bike up this morning and all is fine, idled perfectly up to temp and then idle dropped down and bike stalled...
Played about with it and now it keeps dropping down. Suddenly the dreaded orange light comes back on, only this time its Fault Code 14.
I've looked this code up and its the 'Intake Air Pressure Hose'. Can anyone advise any further on this? Is it the hose on the front of the airbox? If so, I put that back on correctly!
If I have to take this bike apart one more time I think ill cry.
Thanks in advance,
Stu
Thanks in advance,
Stu
