Blavenia
Okay, when the cables on the Exup valve in the GenII muffler are disconnected, the flapper is wide open.
When re-connecting the flapper valve to the cables, should the Exup valve be turned and then the cables attached so it starts off closed, or should it always be open until the cables pull it so it gets more closed?
Does this make sense?
I figure at idle the Exup valve in the exhaust needs to be fully open so it can close via the motor to produce backpressure during certain throttle openings.
I just wanted to make sure I put it back together correctly!
