Oliverjohn
Hi all I have removed the front cat on my 07 fz1 and fit a akrapovic exhaust but I have been told to leave the baffle in because the bike need back pressure is this correct :thinking:
Take the baffle out & leave it out, you are just robbing yourself of the gains of an aftermarket exhaust leaving the baffle in. Ride the bike and if you dont like the popping open up the airboax and block off the snorkel with a plug, marble, screw, silicone or anything that will do the job and no more popping.
Once you get the AFRs fairly well dialed in, some of the popping may return, even with the AIS plugged. The underlying issue is that the AE and DE in the stock ECU gets a little hosed without the valve in the exhaust and the flies up top. The PC5 simply does not have enough adjustment capabilities for the transitions.
Beast
