zaruz88
cruising in 2nd gear at 3500rpm (31 mph) bad for engine?
is cruising like this bad for the engine. I ask this because the temperature stays between 95 degrees C and 100, the fan kicks in at 100 until the temp is back down to 91: but then it climbs back up to 100 and repeats maybe 3 times in one hour of commuting. Is this sustainable for the bike or should I cruise in a higher gear at a lower rpm range?
