schleppy
I scored a great deal on one of the Creese1 fender eliminator kits. The kit came with the plate light, FE bracket, and some LED blinkers (I didn't use them, yet).
Here is what his EBay listings look like:
2006 2007 FZ-1 FZ1 Fender Eliminator BLACK logo TSM: eBay Motors (item 330494476276 end time Nov-15-10 15:23:50 PST)
The FE itself is extremely well made, and looks quite nice. It doesn't come with enough hardware to install it really well, but a few washers will do the trick. Getting the stock blinkers to work was also a bit of pain, but again, washers will do it. The LED plate light it comes with is a really nice little piece, but it's not very bright, and the wiring is an absurdly small gauge. It's good enough.
Pic time:
The "washer sandwich" I ended up with to make the stock blinkers mount well:
Here you see the stock nut+bolt from the stock FE, a washer added, and a rubber gasket I took off the stock FE and sandwiched between the washer and the new FE. It worked really well.
Even if I didn't get a deal for this setup, I would buy it again at full price. It's pretty nice.
Pic time:
