va_rider
Wizard
I hate reposting stuff I see on the "other" forum... but... I think that this is important enough...
CRADAR
An Android app that senses when you fall on the bike, and sends a message to one of your contacts.
CRADAR is a man-down application that runs on any Android phone.
CRADAR senses when you fall, waits 30-120 seconds (whatever you set it for), and if it doesn't see you move at least 8 feet, sends a text message to one of your contacts telling them you might be hurt. This gives your contact a chance to call you to see if you're ok.
In the text message is a link to Google Maps with your GPS coordinates.
If they don't get an answer, they know exactly where you are, and have the GPS coordinates so other people can find you too.
CRADAR starts in the configuration screen.
You can leave the CRADAR screen by pressing the back button. CRADAR will continue running in the background.
If you want CRADAR to stop monitoring, return to the CRADAR screen from the notification bar, and tap the Stop Monitoring bar.
Once a fall has been detected, your phone will start ringing and vibrating, and the counter will start.
If you move more than 8 feet, or tap the "I'm OK" button before the timer runs out, the alert will be cancelled and CRADAR will continue monitoring.
If you do not move at least 8 feet or tap the "I'm OK" button, CRADAR will send a text message to your emergency contact in the following format:
"My phone detected a fall. I may be injured. 42.484506368637085,-76.48738503456116 - Google Maps"
Your contact can tap the link and see your exact location in Google Maps.
CRADAR is a free Android application from ActionXL. Use your Android phone to search the Marketplace for CRADAR, or scan this code with any barcode scanning application. If you are using your phone to view this page, tap the QR code to download Cradar from the Marketplace.
CRADAR
- Tap the contact line to change your emergency contact.
- Tap the message line to change the message. Note: There is a maximum limit of 48 characters due to the maximum text message size. The rest of the text message will be taken up with a link to Google Maps and your GPS coordinates.
- Tap the timer to change the number of seconds to wait before an emergency notification is sent.
- Once you have configured CRADAR, tap the Start Monitoring bar.
