Drinky
So I have my FZ1 (07) for about 4 weeks now, and I wanna make it even better than it already is.
Biggest issue I have right now is the front brakes, Its got 33000 km (20.000 miles) on the clock, no idea if the pads have already been replaced,
but I think it brakes a little to sponge like, I can pretty much brake like an idiot and still the ABS wont kick in, and I keep rolling. which is not a good thing..
(ABS kicking in isn't either, but I should be able to block the wheel if I wanted to, this just prooves the brakes dont work properly, I wouldn't even need ABS right now)
So besides replacing the pads, I want to make them better than stock. If that means a different disk&pads so be it. What kind of disk/pads should I get? (for a reasonable price, im not planning on swapping everything)
I'll get steel braided lines as well.
Next up is suspension. I like the stock better than what I had stock on my FZ6, and since the entire thing is adjustable, I'll look into optimizing settings first. But on my fz6 I had hyperpro progressive springs. Would that improve suspension even further on the FZ1? Or would it be a waste of money?
Also I'm getting an akrapovic slipon, the air filter is pretty dirty so I'm considering BMC/K&N, or should I stick with the stock filter??
Is it hard to clean the bmc/K&N properly?
And last but not least, I'm considering getting a powercommander.
But I see the power commander 5 for 2009 model, and power commander 3 for 2009, I thought there was no difference between 07-09, and only from '10 on it might have a different ECU??
any tips are appreciated!!
(other mods/planned: rizoma rearsets, pazzo levers (already installed), LED lights for the outer 2 small lights, and looking into more, if you know any good mods pls let me know!)
